Fuel Leak/Rollover Valve????
Old 04-05-2013, 05:23 PM
Lt1son's Avatar
Well have around 400 miles on my new motor pulled it in garage today and noticed fuel puddle near left rear wheel--get under car and there is a white valve attached to the brake line bracket right near fuel pump plug-Is this a rollover check valve?? Any ideas would be great---tank is near empty and leaks when car is running---this just started like i said have 400+ miles on this setup and never noticed any puddle. Thanks
Lt1son is offline
Old 04-05-2013, 09:27 PM
Re: Fuel Leak/Rollover Valve????
No, it is a vent for the tank. Are you sure the fuel is not from the EVAP canister? It is in the LR wheel well.
shoebox is offline
Old 04-06-2013, 08:36 AM
Lt1son's Avatar
The canister i saw. How would the full get in there.. i did delete evap w new motor and was thinking to much pressure in take is forcing it out. Was going to try to drive w cap off and see what happens. a lot of pressure when i took cap off.
Lt1son is offline
Old 04-06-2013, 08:49 AM
I think you answered your own question. You deleted the ability to purge fumes from the tank. They may have condensed and soaked the canister. Why delete they EVAP?
shoebox is offline
Old 04-06-2013, 08:57 AM
Lt1son's Avatar
My old man needed the solenoid for his vette while my car was apart. and i never got another 1, actualy thought about that after i posted it. thanks for your help. ill keep everyone updated.
Lt1son is offline
10-31-2016 11:09 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
07-04-2005 05:00 PM
Cam28_boy
08-06-2002 08:40 AM
Quick Reply: Fuel Leak/Rollover Valve????
