Fuel Injectors problems?
Old Jan 10, 2009 | 10:55 AM
  #46
twcblackhand6970's Avatar
That was me driving around for awhile, and stopped for a minute or two because I heard a noise that turned out to be a rock in my tire treads.
Old Jan 10, 2009 | 11:06 AM
  #47
You're recording at an 18-20 frames per second rate. That's not necessary. The PCM only updates 9 times per second. You could go to 5 frames/sec, and reduce the size of the file by 70%, without losing anything.
Old Jan 10, 2009 | 01:15 PM
  #48
sbs's Avatar
sbs
Haven't looked at the logs, but when I read this:
Originally Posted by dbrunner2
There's certainly something strange happening on the right side of the engine...it looks like the PCM is seeing a right O2 voltage that hovers around 0.55 no matter what...when you subsequently opened the throttle wider, the right O2 starts reading very lean and then returns to normal.
I immediately thought "wiring"
and then the very next post says:
Originally Posted by twcblackhand6970
I replaced the right sensor awhile back because the right sensor connection was burned.
Old Jan 10, 2009 | 01:28 PM
  #49
I didn't look at the record rate, I just clicked log...I'll look into the recording options.
Old Jan 10, 2009 | 09:15 PM
  #50
I made a shorter run. I tried lowering the record rate but it won't let you change anything. So I did a shorter drive this time, trying to hit all the cells I could and getting some WOT runs in. I also, after the run, backed timing down where it was needed to get rid of spark retard. Hope this one is easier on the eyes. HA.
http://fb.esnips.com/doc/9fd1c70f-b0...stDRIVEshorter
Old Jan 12, 2009 | 01:20 PM
  #51
Any input on the last run?
AdsoYo
May 2, 2018 03:21 AM
RUENUF
Mar 13, 2016 03:39 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
