fuel injectors
Old May 10, 2005 | 04:45 PM
Zigroid's Avatar
fuel injectors
need to buy fuel injectors for my car, gonna buy from racetronix most likely but im not so sure which to buy... 32s 37s 38s or 42s?
my stuff simplified:
383, LE3 heads/cam/ported intake
32s are cheaper but I dont know if they'll handle over 450 fwhp, 37s, 38s and 42s cost the same I believe.
there MAY be nitrous in my future, so Ive been leaning towards 42s.
Old May 10, 2005 | 11:09 PM
Re: fuel injectors
Depends how conservative you want to be on sizing. If you use the typical online injector size calculator, for 450flywheelHP, with an 0.50 #/HR/HP brake specific fuel consumption (BSFC) and shoot for the recommended 80% (max) duty cycle, you get a requirement of 35.2 #/HR (for an injector flow rated at a 43.5psi fuel system pressure). Anything larger than that will work comfortably with your engine, and give you a cushion for future improvements. Going "large" (within reason) doesn't hurt you.
If you have a really good/efficient tune, and are willing to push the injectors to 90% duty cycle, you could get by with a 30 #/HR injector.
I would personally use at least a 36# injector, but many will tell you they can make 450flywheel on the stock injectors. Defies logic, because an injector can't operate at more than 100% DC.
Old May 10, 2005 | 11:20 PM
tardy007's Avatar
Re: fuel injectors
Hmm, ,so given my setup, do you think 30# svo are enough. I am gonna be putting the car together this weekend and its not to late to take them back. And what do you recommend since svo doesn't make a 36# (Don't mean to hijack this thread)
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
