Fuel Injector question
Old Feb 2, 2003 | 08:38 PM
godbk's Avatar
If i was to replace my fule injectors on a 94 Z28 LT1 with the factory fule injectors that are 26 lbs/hr what would be the best one and the best size for my car?
Old Feb 2, 2003 | 09:17 PM
rskrause's Avatar
Moderator
Re: Fuel Injector question
Why replace them? I think they were rated at 24lbs, and there's nothing wrong with stock injectors. Unless they are malfunctioning or you have mods that make more than ~400hp you have nothing to gain, and if you use injectors significantly larger or smaller than stock you will need to reporgram your PCM.
Rich Kraus
Old Feb 2, 2003 | 10:54 PM
godbk's Avatar
Well im having a hesitation at low rpms and i was reading in the other post that they have found it to be the injectors thats why i was asking. Or do you recommend that i take them off and clean them if so what should i use to clean them.
AdsoYo
May 2, 2018 03:21 AM
LT14LIFE
Feb 9, 2015 09:35 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
