Fuel Injector ?
Old May 29, 2005 | 04:25 PM
joshp007's Avatar
Fuel Injector ?
Will 28# injectors off a ls1 interchange with lt1s?
Old May 29, 2005 | 07:11 PM
96capricemgr's Avatar
Re: Fuel Injector ?
LSX motors use a higher fuel pressure so their injectors are rated at that higher pressure, in an LT1 fuel system with stock pressure these would flow no more than your stockers. Any injector swap should be accompanied by a reprogram because they function a little different, with that they can be made to work.
Old May 29, 2005 | 07:56 PM
joshp007's Avatar
Re: Fuel Injector ?
Will they work with an adjustable fuel pressure regualtor?
Old May 29, 2005 | 10:26 PM
Re: Fuel Injector ?
In affect, the 28# (@ 4 bar) LS1 injectors flow the same as your stock 24# (@ 3 bar) LT1 injectors. You could increase the pressure on your stock injectors to increase their flow capacity. If you bump your fuel pressure to 4 bar (58psi) the stockers will flow 28#. Don't go any higher than that on the pressure though... the RP ball & seat injectors don't like high pressure.
Sounds like you are going to be seeing a serious HP increase with all the parts and money you've put into it.... why are you trying to "poor boy" the injectors? Why not just get some 30, 32 or 36# injectors (depending on your flywheel HP) and do it correctly?
Old May 29, 2005 | 10:35 PM
joshp007's Avatar
Re: Fuel Injector ?
Well I am just out of money and I have a set of ls1 injectors to get me by until I can get some 30#s. I just wanted to know if the 28# would work for me until I get my walbro pump and 30#ers
Old May 30, 2005 | 07:13 AM
Re: Fuel Injector ?
By the time you bought use LS1 injectors and an adjustable regulator you would be pretty well at the cost of just buying some SVOs and doing it right. The SVOs are only about $220 for a set of 8 and are far and away the favorite with tuners.
Old May 30, 2005 | 10:16 AM
joshp007's Avatar
Re: Fuel Injector ?
Well actually I got the 28#s and the FPR for 100 total. I plan to upgrade to 30s soon though
Old May 30, 2005 | 11:46 AM
speed_demon24's Avatar
Re: Fuel Injector ?
Why would you put in the 28#'s when they are the same as you're 24#'s?
Old May 31, 2005 | 08:58 PM
arnie's Avatar
Re: Fuel Injector ?
Maybe cuz it ain't sinkin' in. I believe there are two other similar threads in LT1 Tech at the present time.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
