Fuel Filter/Opti?? Need Help!!
Old May 29, 2003 | 08:07 PM
mrz28M6's Avatar
Well this just started the other day but my car is very very doggy especially in low rpms' at first i thought i had bad gas, so as soon as i ran out of gas, i filled up with premium and poored a bottle of heat into the tank. Now the car is having alot of problems starting. Anyone have any ideas? My first thought was a clogged fuel filter, but now since the car is having trouble starting i thought maybe an opti? Any help would be greatly appreciated!!
Old May 29, 2003 | 08:18 PM
NiteRider's Avatar
Change both, fuel filters are like 5 bucks but i'd say it's your opti, also check your spark plug's and wires.
Old May 29, 2003 | 08:22 PM
mrz28M6's Avatar
ok i am going to do the plugs and wires and the fuel filter first cause they're the cheapest, any idea on where the fuel filter is located??
Old May 29, 2003 | 09:06 PM
PatriotTA's Avatar
Driver's side, near the fuel tank, underneath the car. About where the door ends. Shoebox might have a pic on his site, otherwise consult a Haynes or Chilton's
Old May 29, 2003 | 09:08 PM
97silverz28's Avatar
The fuel filter is aprox. 18" forward of the driver's side rear wheel attached to the subframe. If you stick your head under there look/feel for the fuel & brake lines.
Old May 30, 2003 | 09:32 AM
mrz28M6's Avatar
ttt - any more ideas on what this could be??
Old May 30, 2003 | 09:39 AM
mrz28M6's Avatar
oh i forgot to tell you guys but this happens when the car is cold or warm.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
2001CamaroGuy
Apr 5, 2006 10:56 PM
tbyrne
Jul 2, 2002 05:37 PM
