fuel filter and coil replacement in driveway? how hard..
Old Sep 29, 2003 | 07:32 PM
Caps94ZODG's Avatar
Unhappy fuel filter and coil replacement in driveway? how hard..
OKay guys trying to fix a problem..
http://web.camaross.com/forums/showt...7&goto=newpost
thats the problem in the link..now I do have a MSD coil ready to go in..and just picked up the fuel filter..now untill recently Ive had a place to get these things done with a lift and such..now I just have a driveway and a good assortment of tools..car ramps and a jack..and little light for underneath...
question is how long and the PROPER way to replace the filter in my car? anything special other than just popping the gas cap off?? to relieve the pressure?? and if so..what to do next..all in all driveway fix time for a filter on a jack or ramps??
second the coil..I never done a coil before..any snags or hangups to this?? or is it just something that looks pretty easy to take apart and put back together?? and how long for driveway time...
can it be done in 2-3 hours for both (sun sets around 6)??
Old Sep 29, 2003 | 07:35 PM
1msfyter's Avatar
Purge the fuel on the fuel rail(back of intake) Jack up rear of car enough to crawl under. Use a few rags and 2 open ened wrenches. the other end clips in the hose . VERY easy to do.
The coil is pretty strigt forward. disconect bat. remove intake and air pump if needed . Bolts are easy to get to.
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
