Fuel Disconnect Tool
Yeah I ended up getting it off, I had this ****ty plastic tool I rented from AZ but it worked after a few tries, the return line was a PITA because you cant really see what your doing. I ended up sticking the tool in, pushing the connection inward and then quickly trying to pull it out.
The cheaper the tool is the harder it will be to get off, but it will work. You have to push in hard with the tool and then push the line towards the tool really hard. Don't rip it off, though, because I don't think you can replace the clips in the line.
It helped me when the lines finally popped off and I could see how it works. There are metal clips up inside the top of the line which the tool presses outward and lets the line pop off. Its super important to get that tool pressed up inside the top part of the line before you tug on it. I used the handle of some pliers to pull upwards on the line after the tool was in place.
Wow I haven't been with a woman in a long time.
Guess I'll go to the mall/Sears to look at tools and chicks.
carguyshu
Jan 22, 2017 11:19 AM
ChrisFrez
Feb 22, 2015 08:47 AM
AndyO2000Z
Jun 23, 2002 09:56 PM
