Fuel delivery problem?
Old 05-19-2004, 11:12 AM
AlexBarabas's Avatar
58k miles on the car... driving today, I noticed a "hiccup" in 5th at about 1,500rpm with the throttle about 1/4 open. At first, I thought it was the clutch slipping/catching, but I've got a pretty new clutch and I don't abuse it. I ruled that out after putting it in 6th and flooring it -- no slip at all, just the same hiccup once or twice at low RPMs with the throttle open. It seems to do this now in every gear under the same conditions -- throttle sightly open. I noticed no RPM drop during the hiccups what-so-ever. What gives? Could it be the fuel filter? It's never been changed.
AlexBarabas is offline
Old 05-19-2004, 11:19 AM
DonHood's Avatar
Sounds like you may have a plug wire that's arcing somewhere.
DonHood is offline
Old 05-19-2004, 11:36 AM
TobyZ28's Avatar
Might want to change that fuel filter too every 2 years
TobyZ28 is offline
Old 05-19-2004, 11:46 AM
I just changed the fuel filter without jacking up the car... and without even being able to see the whole thing! Time to go start it up and take it for a spin round the block!
Old 05-19-2004, 12:03 PM
WOW, runs like a charm now... I cleaned the TB w/ some spray cleaner too and both combined, I get a huge increase in TB response. The old filter had black gas pouring out of both ends! The inside was incredibly black -- I'm blaming someone at Hess for this one!
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
Scottyboy
02-11-2015 10:28 PM
01-13-2015 09:52 PM
ChrisFrez
12-07-2014 06:01 PM
Quick Reply: Fuel delivery problem?
