ft-lbs on diff cover?
Old May 22, 2003 | 12:47 AM
SSTAT's Avatar
I just got the baby out and Im getting ready to go down for the gathering 7. I changed my rear end fluid today and my generic manual says to torque a 1/2" bolt to 50 to 80 ft-lbs but that seems awful tight, is that right? Also my SS came with the Torsen and that "AAF" (?) aluminum diff cover, if that makes any difference.
Thanks,
Pat
Old May 22, 2003 | 01:12 AM
cals400ex's Avatar
i believe the 1/2 inch bolts get 22 ft/lbs and the check level plug gets 26 ft/lbs. i am not 100% sure but thats whats coming to mind.
Old May 22, 2003 | 01:13 AM
anaik's Avatar
25 lbs ft for the aluminum cover bolts. If you have the set screws that preload the bearing caps, those are 5 lbs ft.
Old May 22, 2003 | 09:06 AM
SSTAT's Avatar
OK, one more dumb question, so what if I torqued them to 50!? Should I back off? I'm afraid it will leak then...or will it shatter under stress if I leave it that tight?
Thanks-
Old May 22, 2003 | 09:10 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
22 lbs
from memory..
damn i'm good.
and just see if it leaks... you've already overtorqued everything...
retorque if you want
realistyc
Jul 28, 2015 07:32 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
240ssLs3
Jul 13, 2015 05:06 PM
CARiD
Jul 7, 2015 08:19 AM
SergheiS
Jul 5, 2015 03:27 AM
