Front wheel noises -- owls?
Old Jan 9, 2004 | 12:50 AM
GPZ1100's Avatar
Hello,
Got a strange noise coming from the driver side front area when driving that car at low speeds after warm up (less than 10 mph).
This sounds like a whoooo---whoooo---whooooo sound.
Not metailic sounding, but more like something is rubbing.
I've recently mounted my snow tires with steel wheels to the car. Same wheels I used last season and the season before.
No noises are present when the car is cold, nor when the brakes are applied.
Almost seems like the brake pads are rubbing against something, but can't imagine what since there is no pulsation in the pedal...
Noise occurs both when slowing down and accelerating.
Any ideas..
Thanks!
Old Jan 9, 2004 | 02:09 AM
nas-T-72z's Avatar
itz jus fo decarachuns!!! lol j/j but seriously look at your wheel hubs and check for play. other than that it could just be tires. i know my rear tires howl plenty. 335/35/17s
Old Jan 9, 2004 | 02:13 AM
GPZ1100's Avatar
These are snow tires... 215/60/16 or even 215/70/16 ( I forget the profile)...
Old Jan 9, 2004 | 05:30 AM
magius231's Avatar
try swapping your old wheels/tires back in and see if it goes away. If it doesn't, you could be looking at stuck calipers or a wheel bearing going out.
Old Jan 9, 2004 | 07:53 AM
GPZ1100's Avatar
Something else I just realized.
When I pulled off the summer tires, both front wheels had uneven wear --- the insides of both tires had more wear than outside.. Rears were wearing evenly.
I wonder, given that the snow tires had even wear when i put 'em on, that due to the worn out suspension, it's actually the tires themselves that are 'rubbing', which is what's causing this noise.
Granted, it's not a good thing, but a full suspension upgrade is not in the budget at this time. The snow tires are on their 4th season, so it'll be time to replace them next season as well, so uneven wear is not much of a problem either.
I'll definitely jack the car and see if there's any looseness or binding in the wheels.
Thanks!
carguy0119
Apr 11, 2016 11:11 PM
BigWil
Mar 29, 2015 12:24 PM
jj71787
Dec 30, 2014 02:15 PM
squarehead
Nov 21, 2014 08:02 PM
z28projects4ever
133
Jul 26, 2002 01:54 AM
