Front Skinnies
Old Jul 17, 2003 | 03:02 PM
93ZM6Tally's Avatar
Front Skinnies
Just got some Weld Draglites 15x3.5 skinnies. Like usual did some research on CZ28 and want to ask a few questions.
1. Looks like I'll need the 5/16" spacers. Is this correct. And if so do I also need to get longer wheel studs.
2. If I do need wheel studs, what size and length? Won't longer lengths mess with my "street" wheels which have closed end lugs? If so what can I do?
3. It's also my understanding that I don't need to grind the front calipers if I use the wheel spacers.
Thanks.
Old Jul 17, 2003 | 03:30 PM
Yes, 5/16" spacer.
Yes, longer studs required by NHRA
Linenfelter and GMPP sell a 2.67" M12 knurled stud that will fit, and just barely meets NHRA (12mm of the threads must be be engaged in the "hex" protion of the nut). Problem is, these include about 5/8" of unthreaded "end" that stick way out of a stock closed lug nut. I had to drill completely through my closed ZR1 lugs, and thread the entire length, and there is a huge 1" of stud poking out of the nut.
No grinding of calipers with spacers. The interference is not the caliper anyway. It is the spring that holds the pads in the caliper, and the big horizontal bar on the steering knuckle that the caliper/pads rest on.
This pic will make you sick
Old Jul 17, 2003 | 03:48 PM
93ZM6Tally's Avatar
Thanks Fred. You're right the picture ain't pretty but I'd rather live with that than the alternative.
Mark
Old Jul 17, 2003 | 03:56 PM
I ran with the stock studs until they refused to pass me in "tech". They nailed George Baxter for the same problem, the same day, and his car was running low 9's and pulling 4-ft wheelstands. No problem with the stock studs... but NHRA doesn't make these rules up just for the heck of it.
Old Jul 17, 2003 | 04:04 PM
93ZM6Tally's Avatar
It wouldn't be any fun to have a front wheel problem with that kind of speed and horsepower thats for sure.
Old Jul 17, 2003 | 05:28 PM
revtime's Avatar
Not pretty, but then if my car was as fast as yours Fred I would not mind a little extra stud action.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
jwade88
Jun 14, 2015 09:38 PM
KillerTA
Wheels and Tires
May 31, 2015 12:20 PM
Javier97Z28
Jul 24, 2002 08:13 AM
