Front seal under hub leaking can you take off hub and change it out?
Old May 5, 2005 | 12:36 PM
80TA's Avatar
Can I change out that front seal under the hub.I realize have to pull hub off the engine.Or do you have to take off pan? Anyone changed it with pan on.Its not leaking super bad but enough to annoy me.Maybe could rtv or something from front if can't change seal.Don't want to drop the pan right now.
Old May 5, 2005 | 12:59 PM
firetird's Avatar
Re: Front seal under hub leaking can you take off hub and change it out?
if youre talking about the front main seal, then yes you can change it without pulling the pan. it actually goes through the timing chain cover.
before you change the seal, i would make sure that its not leaking from the water pump seal that goes through the timing chain cover. if you do end up replacing the front main seal, its a pretty easy job. you will need a pully puller and the rest of the tools are common.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Brake_L8
Jan 20, 2015 09:44 AM
1LEThumper
Jul 14, 2003 12:45 PM
