Are the front O2 sensors used at WOT?
Old Mar 27, 2004 | 06:02 PM
stereomandan's Avatar
Just curious. If you have an exhaust leak that normally causes the car to run rich, does it effect WOT at all for fuel trim?
Dan
Old Mar 27, 2004 | 06:05 PM
RamAir95TA's Avatar
The O2s are NOT used at WOT as the PCM enters PE mode, but part-throttle conditions are used to determine delivery at WOT. If you have an exhaust leak anyway, your WOT performance is going to suffer.
Old Mar 27, 2004 | 06:14 PM
O.k. Thanks
So if it's running rich at partial throttle, it will also run rich at WOT.
I wasn't sure if WOT tables were just set, and not adjusted. Thanks.
Dan
Old Mar 27, 2004 | 07:35 PM
JSK333's Avatar
I have seen the short-term BLMs change at WOT if the AFR is extremely rich or lean, indicating they are used.
They are definitely reporting data, as a simple scan will show. It seems they are also used to correct the AFR in extreme circumstances.
Old Mar 27, 2004 | 07:48 PM
Thanks guys. I guess that answers that! I need to find that leak!
I wish I could hear it when the engine was just idling. I only hear it at medium-heavy load. I can't run that fast next to the car to find out where it's coming from.
Dan
Old Mar 27, 2004 | 08:01 PM
JSK333's Avatar
Smoke it with Seafoam. You can manually open the throttle under the hood too.
Old Mar 27, 2004 | 08:08 PM
Now that my O2's are so dang easy to get to with my headers, I think I will unplug them, plug up the bungs, and seafoam it.
Good call.
Dan
BigWil
Mar 29, 2015 12:24 PM
captcorvette
Mar 7, 2015 12:37 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
