Are the front O2 sensors used at WOT?
The O2s are NOT used at WOT as the PCM enters PE mode, but part-throttle conditions are used to determine delivery at WOT. If you have an exhaust leak anyway, your WOT performance is going to suffer.
O.k. Thanks
So if it's running rich at partial throttle, it will also run rich at WOT.
I wasn't sure if WOT tables were just set, and not adjusted. Thanks.
Dan
Dan
I have seen the short-term BLMs change at WOT if the AFR is extremely rich or lean, indicating they are used.
They are definitely reporting data, as a simple scan will show. It seems they are also used to correct the AFR in extreme circumstances.
Thanks guys. I guess that answers that! I need to find that leak!
I wish I could hear it when the engine was just idling. I only hear it at medium-heavy load. I can't run that fast next to the car to find out where it's coming from.
Dan
Dan
Jul 4, 2005 05:00 PM
You can manually open the throttle under the hood too.
