Free mods for LT1?
Old May 27, 2003 | 10:38 AM
SumAnFGuy2002's Avatar
Free mods for LT1?
Hey everyone...
I was wondering what sort of 'free' mods I could do to my LT1 other than removing the MAF sensor? I am in high school and I don't have much money at all to add many more expensive mods to my car, so I am looking for things that I can add for basically nothing. If not free, how about some mods that are inexpensive?
Thanks everyone
Allen
Old May 27, 2003 | 10:55 AM
Antz97ZNJ's Avatar
the only one worth anything really is the TB bypass..and thats only a few hp...do a search you'll find plenty...check out www.ws6.com
Old May 27, 2003 | 11:49 AM
WhiteThunderZ28's Avatar
You can remove the end links on your sway bar, that will help transfer more weight to the rear wheels and the front of yor car will rise up more..
Old May 27, 2003 | 12:01 PM
Screamin95's Avatar
But only do this mod at the drag strip!!
Old May 27, 2003 | 12:03 PM
why do it at a drag strip, I drve around wth a disconecte swaybar all the time with no problems
Old May 27, 2003 | 12:17 PM
teke184's Avatar
what kind of car do you have...that may help us give you some ideas.
free:
tb bypass
removed maf screen
gutted cat
relocate the iat sensor closer to air box
cut face of airbox off and install K&N (or similar) filter
put scoop on splash guard infront of tire to direct cool air towards air filter
remove weight (spare, jack, stereo, back seats, rugs)
inexpensive:
air foil $40
homemade cold air ~$75 with k&n cone filter
use after market CAI for ~$100-150
cutout $35 for cutout, $25-40 to weld it in
poly bushings for lower control arms and panhard bar, and weld them up to box them in if you have access to some scrape metal and a place to do the welding ~$50 depending on welding
pulleys $75-100 (cheaper if used)
short stick shifter handle if it's a manual $55 (link in the sig)
160* thermostat to run cooler $20
new plugs and wires $75 (www.thunderracing.com you can get taylor spiro-pro 8mm wires and set of NGK tr55 plugs shipped)
if it's 94/95 a basic computer reprogram from www.pcmforless or madwolf (on the board) to lower fan temps, increase spark, change shift points/firmness...etc...$100
Old May 27, 2003 | 01:09 PM
Do you have a link for that cause I wanna move mine.... Thanks
Old May 27, 2003 | 01:17 PM
jimbo95Z28's Avatar
there are some good instructions for free mods on www.projecttransam.com
Old May 27, 2003 | 01:46 PM
jer4251's Avatar
whats the IAT sensor? i have a 97 ss with ram air. anything i can do?
Caps94ZODG
25
Oct 2, 2003 06:30 AM
Fusion93Z
Sep 10, 2002 06:46 PM
Thebeast431
Aug 25, 2002 05:06 PM
GC456
Aug 8, 2002 11:53 PM
Thebeast431
Aug 8, 2002 01:39 PM
