Found hesitation problem...how to repair o2 & misc wire harness to PCM?? (Burned)
Old 03-28-2004, 12:16 PM
Robbie's Avatar
Got to looking and seen where a set of wires were touching my header primary Well there pretty toasted and frankly I dont see how its still running. Anyway I had a code pulled the other day and it was a passenger side 02 bank circuit problem. So can I splice the wires and add new wire where the burnt was or am I gonna have to get a whole new harness. Im guessing i can splice them.
Robbie is offline
Old 03-28-2004, 12:42 PM
Scream And Fly's Avatar
Sure, you can splice it. Use the same gauge and type of wire to avoid possible resistance problems. Also, use heat-shrink tubing on the connections.
Greg
Scream And Fly is offline
01-05-2015 07:14 PM
07-04-2005 05:00 PM
gh0st
09-01-2002 10:24 AM
Teal94V-6
08-31-2002 09:21 PM
Rich_z28
08-29-2002 10:44 PM
Quick Reply: Found hesitation problem...how to repair o2 & misc wire harness to PCM?? (Burned)
