Formula Taillights leak?
Old Sep 7, 2003 | 11:05 PM
Fux0redImages's Avatar
Thumbs down Formula Taillights leak?
I have a 1994 formula and my taillights leak water. Not into the car but actually into the taillight. One of the actual bulbs burnt out cus of this. Should I just get new lights, or is it just something simple?
Old Sep 7, 2003 | 11:30 PM
WS6pete's Avatar
try to seal the plastic in the tailight housing.., if its too big of a leak, you need new tailights...ive read of this happening to alot of pontiac lights..(including mine) , the plastic actualy seperates on the taillight housing..hasnt happened to the new one...yet
Old Sep 8, 2003 | 03:14 PM
BigEvil's Avatar
Had the same problem, went ahead and got new ones.
Hey, if you like you can switch to the honeycombs from the 98-02.
Old Sep 8, 2003 | 07:21 PM
97FormulaWS-6's Avatar
you can open them up and re-seal them with some RTV.. there are instructions on my website
Old Sep 8, 2003 | 07:35 PM
Where is this website you speak of, I see no link in your sig?
Old Sep 8, 2003 | 09:17 PM
no... but see the little red buttons underneath all the posts... see the red Website one under this post.... Click there...
Old Sep 8, 2003 | 11:12 PM
Fatdog's Avatar
Cool
I just only used white caulking behind the kidney shaped thing(you can see where the lines are)and when this dried,Iused a permanent black marker.Also caulked the little hole inside the kidney shaped thing,as this is where I think the water comes from.(The hatch).Hope this helps.(When you pop the hatch and look down on the left,and the right side,this is where I caulked.)
Old Sep 10, 2003 | 09:23 AM
fbird95's Avatar
What did you expect from GM, They did have a TSB (technical service bulletin) for 3rd gens where they wanted you to notch the front bumper with a hand saw, in order to allow the lights to prperly drain and not fog up.
Old Sep 10, 2003 | 10:49 AM
IXLR894Z28's Avatar
Mine had the same problem with yhe drivers side, previous owner just replaced the entire light fixture. RTV seems so much cheaper.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
Formula Steve
Sep 19, 2015 08:48 PM
rideordie
Sep 7, 2015 08:22 AM
cardemo16
Aug 24, 2015 01:04 AM
