forgot to install the reluctor onto my crank.
Old Sep 19, 2005 | 08:36 AM
djm_e22's Avatar
I have a 96 z28 which obviously has the different hub than the 93-95 model. Well I installed everything along with my 96 hub and pulley and forgot to put the stupid reluctor in. Do I absolutely need this or can I just get pcmforless or someone to just program the reluctor(crank position sensor) out of the computer. Also would I have to have the 93-95 hub in order to do this? Thanks for any help.
Old Sep 19, 2005 | 10:42 AM
Z95m6's Avatar
Re: forgot to install the reluctor onto my crank.
Did you by chance put in a double roller chain? If so you don't need the ring. My buddy put in his double roller on his 97 and just left off the ring.
Old Sep 19, 2005 | 10:43 AM
CANTONRACER's Avatar
You don't need it...but you did make up the space difference right?
Old Sep 19, 2005 | 01:20 PM
1racerdude's Avatar
The belt won't line up without it.
Old Sep 19, 2005 | 03:28 PM
sssalah's Avatar
You've probably damaged the hub when it was pressed against the crank key, get a 93-95 hub.
Old Sep 19, 2005 | 04:13 PM
Birdman7389's Avatar
yep, get the old style hub, and have someone program out the CPS, or switch to OBDI
Old Sep 19, 2005 | 10:58 PM
96trans am's Avatar
If its on a Double roller you will need to make some sort of spacer of .067".
Old Sep 19, 2005 | 11:55 PM
Red96Lt1's Avatar
So I'm intrigued, can you put a double roller on an otherwise stock 96+ LT1?
Old Sep 19, 2005 | 11:57 PM
Yes, with the use of a '93-95 hub.
Someone said you can have a spacer made up? I found it easier to get the hub from Jason Cromer.
You need to remove the reluctor for the CPS, and have it programmed out or switch to OBDI
Old Sep 20, 2005 | 12:32 AM
MyTMous's Avatar
does this mean you can use a double roller on a 94, with out any other changes? or do you still need the spacer?
Old Sep 20, 2005 | 02:13 AM
sssalah's Avatar
Everything is possible, you'de have to convert it to vented opti, however.
Old Sep 20, 2005 | 07:33 AM
96trans am's Avatar
I made a spacer out of aluminum to fit inside the hub so it wouldnt rub against the gear. You guys think .067" would actually make that much of a difference to where the pulleys dont line up?
Old Sep 20, 2005 | 07:46 AM
Dave89IROC's Avatar
on a 94 you have to convert to a vented opti, and you need a electric w/p
Old Sep 20, 2005 | 08:54 AM
Hot Rod Hawk's Avatar
Buy the spacer from ATI, they have it.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
lt1matt
Mar 21, 2015 07:35 PM
HectorM52
Mar 15, 2015 10:45 PM
Queens94z28
Dec 20, 2014 09:11 PM
