Which forged pistons?????
Old Mar 22, 2005 | 10:10 AM
  #16
TransAm396's Avatar
Re: Which forged pistons?????
srp -14cc or -16cc pistons...cnc-motorsports..you can get a 383 forged eagle crank, eagle 6" rods (with the L19s) and those srp -16cc nitrous spec. pistons for under 1500.00
Old Mar 22, 2005 | 10:37 AM
  #17
darkangel95's Avatar
Originally Posted by SStrokerAce
Actually Mahle makes the stock LT1 and LS1 pistons, all the way up to custom Next Cups stuff and F1 stuff.
If you want to run a HUGE shot then a custom N2O piston with the top ring land farther down from the top of the piston is the way to go. We are talking about over a 300shot here.
Most times guys kill pistons due to the two things I mentioned. If you build the motor with this in mind it's really not that big of a issue.
Bret
Thanks for the info.
Old Mar 22, 2005 | 03:16 PM
  #18
SStrokerAce's Avatar
No Problem man.... If you need any help finding the Mahles give me a shout.
Old Mar 22, 2005 | 08:33 PM
  #19
LT4orbust's Avatar
Originally Posted by SPEED750
I need a set of forged pistons but not sure what to buy. I have LE2 heads, LE1 cam, the motor won't be turning over 6700rpm and I have a NX wet kit. 150 hp would be my max n20 jetting. CNC motorsports has KB forged for $340ish, these are flat top with -4.7cc reliefs. Are the cheap KB any good? Anybody know of a killer deal out there??
how much do you plan on using the n20
Old Mar 22, 2005 | 08:42 PM
  #20
97Z-M6's Avatar
ross make a flat top nitrous piston with 4cc valve releifs and also has a .300 thick top ring land.
i think the part number is 90645
Old Mar 23, 2005 | 12:35 AM
  #21
.300 down from the top ring land. Hard to find rings that are that thick.
That's a serious N2O piston right there.
Bret
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
