followup to lt1 mystery
Old Jul 15, 2004 | 10:21 PM
  #16
BigBlue95Z's Avatar
Another thing that you might wanna try is unplugging the MAF sensor. If it smooths out, its bad. When you unplug it, it runs in speed denisity(like 93). And also, replace them damn o2s!!!!!
Old Jul 16, 2004 | 10:29 AM
  #17
ponykiller z28's Avatar
about the o2's.... i made a v6-v8 engine swap 2 years ago and the car still has v6 exhaust from the Y pipe back (except flowmaster muffler and tips)
therefore the 2nd O2 sensor (the one behind the cat) has nowhere to hook up. it is just tied up where it won't drag the ground... it seems like it being unhooked would make the car run poor but it has ran fine for 2 years like that so i have a hard time believing it is that sensor.....
however i do have the front O2 hooked up and it could have gone bad. I will replace it and see if that makes a difference.
thanks guys
Old Jul 16, 2004 | 12:55 PM
  #18
I re-flushed the oil to get rid of any gasoline residue and changed the oxygen sensor........
the car cranks up and runs PERFECT with no smoke at all for about five minutes......
so i'm thinking problem solved......
BUT ..... after running perfect for 5 minutes all of the sudden it puts out a large puff of black smoke and the engine DIES!!!
WTF!!!!!!!
what else could be wrong?????
please help guys
Old Jul 16, 2004 | 04:48 PM
  #19
BigBlue95Z's Avatar
Did you replace BOTH the front ones?? Need to do both. The one after the cat only has to do w/emissions, not engine management. And again, try unplugging the MAF.
Old Jul 16, 2004 | 06:46 PM
  #20
i unplugged the MAF and it seemed to run better but it still smoked a pretty good bit
Old Jul 16, 2004 | 11:30 PM
  #21
b
u
m
p
ChrisFrez
Nov 23, 2014 10:33 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
OneBad98Z
Aug 6, 2002 03:23 AM
kevkop94TA
Jul 19, 2002 09:56 PM
