Foiled it up
Old Sep 19, 2019 | 12:03 PM
Germansheperd's Avatar
Foiled it up
Well I think this is my last bolt-on for the old Z28. I should have it back to the track in a couple weeks.
Old Sep 19, 2019 | 03:44 PM
LT5's Avatar
LT5
Re: Foiled it up
What elbow are you using, im going back to the 1le when i can, the trick flow one keeps falling off no matter how tight i get it lol.
Old Sep 19, 2019 | 04:52 PM
Re: Foiled it up
I’m running the 1LE
Old Sep 20, 2019 | 01:49 PM
LT5's Avatar
LT5
Re: Foiled it up
Any notice in gains? I got the tps one and i noticed a gain. plus i cleaned entire tb....was a nice 2 hours messing around lol.
Old Sep 20, 2019 | 02:33 PM
Re: Foiled it up
Make sure the lower part of the air foil is not blocking the idle air passage in the lower "triangle" between the throttle bores. There is a hole at the bottom (floor) surface that feeds the passage to the idle air stepper motor, and another small hole higher up that allows a small amount of air to go directly into the plenum. Block those and you can have issues with idle air control.
Dyno results for an air foil - not the same one you have in the photo::
Drivetrain Modifications #4
There is absolutely no way that anyone could possible feel a 2.4 peak HP gain, most of which only occurs above 5,500 RPM. If you feel it, it is the "placebo" effect.
Old Sep 20, 2019 | 02:36 PM
Re: Foiled it up
No not really. If there was something i could not tell SOTP. Ive done some bolt-on mods since running the car early last May. I will take it back to the track in the near future and make comparisons and final thoughts.
Old Sep 20, 2019 | 04:16 PM
Chimera96's Avatar
Re: Foiled it up
Well the "Butt-o-Meter" is not a very accurate device and typically shows more gains=to whatever the bolt on part costs.
...but as noted any "documented" gain is very low (read next to nothing) and not something you would notice with the Butt-o-Meter
Track times on different days will also not be a valid comparison (DA, 60', etc) as conditions, car, driver are not the same as doing a pass then installing a part then doing a pass same day and even with that the times will vary more than any gain the foil may provide
Will the air foil hurt anything, no...but don't expect it alone will give you anything noticeable that you can feel or even measure on a dyno
Biggest concern of using a air foil if it does block the IAC passages then you will have drivability and idle issues. There are air foils that do have holes if yours does not
Old Sep 20, 2019 | 04:42 PM
Re: Foiled it up
I’ll be certain to factor and compare the DA and the 60’ for my analysis from the last runs and the upcoming outing.
Ws6Envy
Mar 9, 2012 09:00 AM
ACE1252
Aug 10, 2010 12:07 PM
red1984
Jul 23, 2007 06:02 PM
Schurters LT1
Oct 18, 2006 08:40 AM
Schurters LT1
Sep 26, 2006 07:11 PM
