flushing engine after head install?
Old Apr 19, 2004 | 04:06 PM
TenaciousZ's Avatar
What would be the best way to get rid of any foreign debris that might have fallen into the lifter valley after a head install?
Old Apr 19, 2004 | 05:18 PM
blown383's Avatar
ttt I would like to know also!
I think this is the reason why people are told to change their oil after 20 minutes.
-B
Old Apr 19, 2004 | 06:19 PM
TenaciousZ's Avatar
-B
I kinda figured to do a oil change soon after, but would it help to pour oil into the engine and just let it drain out as i'm pouring it? then fill it up and change the oil 20 or so minutes later, then 100 miles change again etc.?
Old Apr 19, 2004 | 11:00 PM
IrocSS85's Avatar
well, I spray a clean shop rag w/brake parts cleaner and wipe it down, then I'll spray the brake cleaner in the crevices to rinse down the rest. be careful not to rinse down the oil/assemb. lube off the cam lobes. then rinse down w/fresh oil. after all that, fill w/clean oil and change soon after startup. I leave the orig. filter in there for initial startup just for this reason. then change oil /filter. same w/inside the valve cover area. everything gets a fresh coat of oil after adj. the valves.
Old Apr 20, 2004 | 04:18 PM
TenaciousZ's Avatar
thank you, I have a feeling I got something in there. Well, with my luck anyway
oldschool
Feb 9, 2016 09:21 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
thenewkid
Nov 27, 2014 09:41 AM
