Springs?
Old Apr 20, 2004 | 10:34 AM
maroon94z's Avatar
Springs?
I've got a set of Crane Gold 1.6 RR's gathering dust. Do I need springs too? This is a stock internal motor with 135k miles. I eventually want to do cam, but not right now. Can I get by with stock springs? Or should I just go ahead and change them? And what spring should I get?
Bill
Old Apr 20, 2004 | 10:37 AM
Brent94Z's Avatar
Super Moderator
Changing the springs isn't *required* but is desired
If you have the means and funds to change them, I'd do it. But, there are several who don't and just use the stock springs.
I am running Crane Gold 1.6 roller rockers in my supercharged 94Z with no problems. I only take it up to about 6100 rpm though.
Old Apr 20, 2004 | 04:39 PM
maroon94z's Avatar
Which ones should I get? Preferably something from Summit.
Do I need anything else?
TIA
Old Apr 20, 2004 | 04:40 PM
97WS6SCharged's Avatar
If you plan on upgrading the cam, go with the springs you will eventually need. If not, then a set of LT4 valve springs are cheap and should work for your application.
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
