flowmaster true duals
Old Mar 4, 2010 | 04:19 PM
StangCrusher350's Avatar
hey guys. i was just wondering from YOUR experiences, how hard is it to build a true dual system? I would like to use this exhaust
http://www.flowmastermufflers.com/sh...0V8&orig=17274
so, correct me if i'm wrong, but wouldnt i just run anpther tube along with another CAT conv. into 1 j bend to an X pipe??
Old Mar 4, 2010 | 04:54 PM
The picture is a catback with a cross-flow single-in/dual out muffler. You can't turn that into "true duals". A J-bend into an X-pipe? Then what comes out of the X-pipe, and how does it get over the axle, with each bank of the engine having its own intermediate pipe and muffler?
Old Mar 4, 2010 | 04:59 PM
RamAir95TA's Avatar
Perhaps you don't have a solid understanding of what a true dual system is. The system you listed is a cat-back which uses a y-pipe to merge the exhaust manifolds/headers into one pipe which is then split through a single in/dual out muffler. A true dual system is something like this:
...whereas each bank has it's own tubing, usually joined by an x-pipe to bullet mufflers which either dump before the rear axle, or go all the way back.
Old Mar 4, 2010 | 05:02 PM
Or without the X-pipe:
Old Mar 4, 2010 | 06:35 PM
sorry for me misunderstanding guys. that helped a lot. So, for the first picture, what all would that consist of with the build??
Old Mar 4, 2010 | 07:11 PM
RamAir95TA's Avatar
Usually you'd just have to fab it up yourself and see what parts you need, starting with bullet mufflers and a universal x-pipe.
Old Mar 4, 2010 | 07:39 PM
my final questions are would i get this 3" piping from a dealer like flowmaster for example? and i was wondering what kind of CATS those were in pic 1
thanks trans!!
Old Mar 4, 2010 | 09:19 PM
LearJet's Avatar
lol, there are no CATS in that picture, neither of them I suspect. If you did use catalytic converters they would go directly after the headers on each side. Most people running duals go without cats if they can get away with it. Depends on your local vehicle inspection rules, or at least your relationship with the guy that is doing the inspection. You can order all the piping you need from summit or jegs. Other places too.
Old Mar 5, 2010 | 07:22 AM
wow... i always though those little things were just small cats lmao. has anyone ever brought their duals out the side of the car before the rear wheel well?? thats what im thinking about doing
Old Mar 5, 2010 | 10:18 AM
xxteenobesexx's Avatar
Smile
https://www.camaroz28.com/forums/sho....php?t=682535:)
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
Formula Steve
Sep 19, 2015 08:48 PM
Sep 11, 2015 09:44 AM
