Fixing intake manifold leak
Old Apr 1, 2008 | 03:18 PM
JJAPHIPPS22's Avatar
I am getting ready to fix my intake manifold leak for the first time are there any mods that I should look into doing while the manifold is off.
Old Apr 1, 2008 | 03:21 PM
2000GTP's Avatar
Rocker arms, valve springs, throttle body bypass.
Old Apr 1, 2008 | 03:22 PM
ss.slp.ls1's Avatar
Essentially nothing is exposed by only taking the intake manifold off. You could get it cleaned and ported.
Old Apr 1, 2008 | 03:31 PM
what rocker arms and valve springs does everyone prefer?
Old Apr 1, 2008 | 03:43 PM
Ironxcross's Avatar
sounds like alot of work, plus you really dont even need to have the intake off to change those..
Old Apr 1, 2008 | 03:58 PM
feenix88's Avatar
New lifters are the only thing I would say because you have to pull the intake to get to them. No performance gained with just them, but cheap insurance if your have high mileage and you foresee rockers and springs being upgraded in the near future.
Old Apr 1, 2008 | 05:37 PM
2000GTP's Avatar
True, but an extra couple minutes to pop off the valve covers and there they are.
Old Apr 1, 2008 | 06:08 PM
Ironxcross's Avatar
yeah, but then you have to take the springs off, but you have to take the spark plug out too and get that air compression thing so the valve doesnt drop and then after you do that 16 times, you have to set your valves. Alot more work then just popping an intake manifold off and putting it back on.
Old Apr 1, 2008 | 06:54 PM
I had planned rocker arms in the future and I wanted to know if they would be easier to do now. The main thing I need to fix is the intake leak, is their a good "how to" for this anywhere besides www.projecttransam.com
Old Apr 1, 2008 | 06:58 PM
ss.slp.ls1's Avatar
Read the section on removing the intake manifold (courtesy of Shoebox):
http://shbox.com/ci/cam_removal.html
Old Apr 1, 2008 | 07:17 PM
Compstall's Avatar
...and several more hours changing rockers and springs. Easy way to turn a few-hour job into a weekend.
alex5366
Feb 17, 2015 08:12 PM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
Dr. Weir
Aug 2, 2002 02:36 AM
