Fixing burned O2 wires
Old Feb 4, 2008 | 07:45 AM
kgkern01's Avatar
I have a feeling that the pass side O2 wires have been burned by my headers given a now have a closed loop miss. If a wire is burned can I just splice in a new wire to the O2 or will it cause problems?
Old Feb 4, 2008 | 07:56 AM
2000GTP's Avatar
Are you getting an SES light? Did you verify that you had a burnt harness?
Old Feb 4, 2008 | 08:17 AM
kgkern01's Avatar
no SES light, tan wire was burned.
Old Feb 4, 2008 | 09:57 AM
white97T/A's Avatar
From my research, splicing in a piece of regular wire will cause some problems. I had the idea of just splicing longer wires on some O2 sensors when doing my headers, and through doing some research I found that O2 wires are not just plain copper wire which is a big reason for buying extensions, the other reason is the plug and play aspect is nice. I would just buy another O2 sensor if it were my car.
Old Feb 4, 2008 | 10:54 AM
ss.slp.ls1's Avatar
Originally Posted by white97T/A
From my research, splicing in a piece of regular wire will cause some problems...the other reason is the plug and play aspect is nice. I would just buy another O2 sensor if it were my car.
What if the wire is burned after the o2 sensor connection?
Old Feb 4, 2008 | 11:19 AM
kgkern01's Avatar
Since my O2 wires are burned at the header on the pass side under the black loom, and regular copper wire won't work, how do I go about fixing this?
Old Feb 4, 2008 | 11:26 AM
If burned on the O2's harness, replace the sensor. If burned on the engine harness, repair (solder and heatshrink).
Old Feb 4, 2008 | 11:34 AM
kgkern01's Avatar
What about just using a wire connector to repair the wire, would that work or would it throw off the O2 readings? I don't have a soldering gun (nor soldered before) but will get one if absolutely necessary to fix this.
Old Feb 4, 2008 | 12:41 PM
walt355's Avatar
You can get a soldering iron at Walmart for about $10. That's what I use and it works pretty good...
Old Feb 4, 2008 | 12:46 PM
You can use a crimp style butt connector, but I would still use a heatshrink to cover it up.
Old Feb 6, 2008 | 08:19 AM
kgkern01's Avatar
Used the butt connectors, and heatshrink covered them. Hope this helps.
grabbem88
Mar 18, 2015 01:25 PM
mattstrike
Mar 11, 2015 07:33 PM
blac94Z
Jan 12, 2015 05:44 PM
IRABuss
Sep 7, 2011 09:08 PM
