Fix Water Pump with JB Weld?
Old Jan 28, 2010 | 09:14 AM
lightskindwonder's Avatar
My water pump is leaking from the top passenger side heater hose press fitting pipe where it mates with the water pump. I've tried putting some rtv around the fitting, but coolant still seems to trickle out. Has anyone had success with JB welding (or other methods) to correctly seal these pipes without buying a completely new unit? The pump was replaced 2 years ago with a brand new GM unit and is not leaking from the weep hole.
Old Jan 28, 2010 | 09:39 AM
wrd1972's Avatar
If you clean it well, score the surfaces, there is a good chance it will work. Buddy once JB'd a cracked coolant wall in boat block. It worked well.
Old Jan 28, 2010 | 09:18 PM
1965GP's Avatar
the reman unit I just put on is doing the same thing. I may try JB jut cause I don't want to pull the F'n thing off again after putting the opti, alternator, wiring harness....
I just want to drive the car!
Old Jan 29, 2010 | 05:58 AM
blkcamaro_z28's Avatar
Quicksteel works great on everything I have used it for. You can pick it up at walmart.
Old Jan 29, 2010 | 09:20 PM
onefastmx5's Avatar
JB has always done wonders for me
Old Jan 29, 2010 | 09:37 PM
94ltz's Avatar
Or you could just fix it correctly.. That's always a great idea.. Not all parts are going to hold forever and ya some times they fail before they should.. Oh well just my .02
Old Jan 29, 2010 | 09:45 PM
Bersaglieri's Avatar
JB weld has held 70psi of boost on my intercooler, it should hold a little water.
-Dustin-
Old Jan 29, 2010 | 11:53 PM
just bought a remanufactured pump from autozone and put some quicksteel around each of the pipes for extra reassurance. hopefully no leaks for a while...
Old Jan 30, 2010 | 04:43 AM
SS44Camaro's Avatar
take the hose off and find a shop that can put new fitting on it and recrimp it. probably not a mechanic shop but a specialty shop. ive got a shop here that does mostly welding stuff but can redo hoses. that is if the hose is expensive, im not sure how much it is.
Old Jan 30, 2010 | 10:16 AM
97WS6Pilot's Avatar
I've used Proseal (JBWeld) on that exact fitting. As long as the surface is clean and you mix it right it will hold forever.
Old Jan 30, 2010 | 12:56 PM
Yup.
Magenta_Hearts
Mar 25, 2015 10:24 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
