Fittment of 4" mufflex.
Old Mar 10, 2004 | 01:26 PM
sssalah's Avatar
Will a 4” mufflex fit over the panhard brace without hitting, what needs to be done besides taking out the heat shield. I’m in the process of an install right now and just trial fitting the system, this pipe (over axle) is a very tight fit.
thanks
Old Mar 10, 2004 | 01:44 PM
My 4" Mufflex was installed by Mufflex, in their shop. The IM pipe essentially "wedges" into the space availble between nthe panhard rod brace and the body. It is in there so tight that is can't rattle. I don't remember them having to remove any heat shield, and I watched the entire install.
4" IM pipe
Old Mar 10, 2004 | 01:47 PM
Brent94Z's Avatar
Super Moderator
I've got this on two cars and in both cases left the heat shield intact. On one car the thing fit like a glove. No rattles at all. On the other I have a very slight rattle that I need to fix but it's nothing too bad.
http://www.bfranker.badz28.com/fbody/exh-0706_IMG.JPG
Old Mar 10, 2004 | 01:48 PM
Brent94Z's Avatar
Super Moderator
A few more for ya
http://www.bfranker.badz28.com/fbody/exh-0700_IMG.JPG
http://www.bfranker.badz28.com/fbody/exh-0701_IMG.JPG
Old Mar 10, 2004 | 02:04 PM
EddieP's Avatar
I was able to get it over the axle without touching anything, but it was a close fit... the over axle pipe had only 1/4" of clearance in 3 places (panhard brace, tank, and the frame). The heat shield had to be removed in my case, but it might be different from car to car... I wrapped the section of pipe that ran next to the tank with exhaust wrap, which hopefully does an adequate job. Anyway, the process took a couple of hours and was a PITA - in fact, I welded up my own hangers out of 3/8" steel rod, since the mufflex hangers didn't give me the fit I wanted.
Old Mar 11, 2004 | 07:08 AM
sssalah's Avatar
Wow, this place is great, many thanks guys
chevydriverlt1
Feb 10, 2010 03:53 AM
Schweet97Z
Oct 23, 2007 11:46 PM
Schweet97Z
Middle Atlantic
12
Oct 17, 2007 06:31 AM
always faster
Jan 15, 2007 08:32 AM
always faster
Jun 13, 2006 09:02 PM
