First Time at The Track after CAM & LTs
Old Jul 28, 2004 | 09:48 AM
SnakeKilla's Avatar
Yesterday I went to Route66 (Joliet, IL) and got the following numbers
best run out of 3
60'.....1.968
1/4.....13.122
MPH....105.94
I was happy with these numbers, but do you guys think I could've broken in to the high 12.XXXs . Weather was 80 degrees with 58% humidity.
95' TA M6
Old Jul 28, 2004 | 09:49 AM
SnakeKilla's Avatar
Re: First Time at The Track after CAM & LTs
By the way, I was NOT spraying.
Old Jul 28, 2004 | 09:55 AM
GREGG 97Z's Avatar
With a slightly better launch you would have been into the 12's on that run. Drop another .10 off your 60 and your there.
Old Jul 28, 2004 | 10:07 AM
slomarao's Avatar
Is your car tuned? or is that stock programming.
Old Jul 28, 2004 | 10:24 AM
SnakeKilla's Avatar
yes, car was dynotune!
Old Jul 28, 2004 | 06:11 PM
95z6spd's Avatar
I would think that you would run closer to mid 12's atleast...Look at my sig.. that is before LT's. The motor is untouched.
Old Jul 28, 2004 | 06:20 PM
simple's Avatar
thats what i'm thinking, i ran 13.1 @ 105+ with boltons and a 1.83 60' (sig)
what was the DA on that pass?
and what kind of tires?
keep working on it tho, do you have a 12bolt?
Old Jul 28, 2004 | 09:44 PM
95z6spd's Avatar
Hey Simple. Your car sounds BADASS. What are the specs on your cam and have you put it on a dyno? I am thinking about doing heads and cam in the future and I was looking at the Ai heads and possibly a 847 cam..
Old Jul 28, 2004 | 09:51 PM
turbo_Z's Avatar
105 mph sounds kinda slow for that cam and LTs. Ive seen guys trap 110 with cc305, stock heads so something isnt quite right. Where were you shifting at or if its an auto what are you shift points? 1.9 60' is probably the best you will be able to get with street tires too but Id still think you could hit 12's with a 1.9 60'.
Old Jul 29, 2004 | 12:04 AM
SnakeKilla's Avatar
I was running zr1 17s rims w/ 315s nitto DRs on a stock rear end, clutch. I dont know what the DA is.
Old Jul 29, 2004 | 12:09 AM
SnakeKilla's Avatar
[PHP]105 mph sounds kinda slow for that cam and LTs. Ive seen guys trap 110 with cc305, stock heads so something isnt quite right. Where were you shifting at or if its an auto what are you shift points? 1.9 60' is probably the best you will be able to get with street tires too but Id still think you could hit 12's with a 1.9 60'.[/PHP]
I was shifting at 6100rpms
Old Jul 29, 2004 | 12:14 AM
SnakeKilla's Avatar
man, it took me a while to figure this out
the cam is a XE230/236 on a 112
It dyno 335/348 SAE corrected
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Noenav
Dec 6, 2014 07:35 PM
