First Time at The Track after CAM & LTs
Yesterday I went to Route66 (Joliet, IL) and got the following numbers
best run out of 3
60'.....1.968
1/4.....13.122
MPH....105.94
I was happy with these numbers, but do you guys think I could've broken in to the high 12.XXXs
. Weather was 80 degrees with 58% humidity.
95' TA M6
best run out of 3
60'.....1.968
1/4.....13.122
MPH....105.94
. Weather was 80 degrees with 58% humidity.95' TA M6
Re: First Time at The Track after CAM & LTs
Originally Posted by 95z6spd
I would think that you would run closer to mid 12's atleast...Look at my sig.. that is before LT's. The motor is untouched.
what was the DA on that pass?
and what kind of tires?
keep working on it tho, do you have a 12bolt?
Hey Simple. Your car sounds BADASS. What are the specs on your cam and have you put it on a dyno? I am thinking about doing heads and cam in the future and I was looking at the Ai heads and possibly a 847 cam..
105 mph sounds kinda slow for that cam and LTs. Ive seen guys trap 110 with cc305, stock heads so something isnt quite right. Where were you shifting at or if its an auto what are you shift points? 1.9 60' is probably the best you will be able to get with street tires too but Id still think you could hit 12's with a 1.9 60'.
I was running zr1 17s rims w/ 315s nitto DRs on a stock rear end, clutch. I dont know what the DA is.
[PHP]105 mph sounds kinda slow for that cam and LTs. Ive seen guys trap 110 with cc305, stock heads so something isnt quite right. Where were you shifting at or if its an auto what are you shift points? 1.9 60' is probably the best you will be able to get with street tires too but Id still think you could hit 12's with a 1.9 60'.[/PHP]
I was shifting at 6100rpms
the cam is a XE230/236 on a 112
It dyno 335/348 SAE corrected
