First Time Changing My Own Oil?????
Old Jan 26, 2003 | 07:05 PM
  #16
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Originally posted by Xride
how much is a quart?
its exactly 1 quart.
its what oil comes in. 1 quart.
Old Jan 26, 2003 | 09:00 PM
  #17
JSK333's Avatar
Here are my few tips...
Get a new magnetic drain plug and some nylon washers (to make a good seal on the plug).
Just use your new oil bottles to hold the old oil, after you've drained it into a pan... put the new filter on, the plug back in, fill it, then empty the drain pan into the empty bottles. Then take them to AutoZone or Pepboys. Works great!
I'd advise against any oil filter wrench tools. You just want to hand-tighten it, after wetting the rubber gasket on it with your finger dipped in some of the new oil.
Enjoy! It's a great feeling doing it for the first time!
Old Jan 26, 2003 | 09:52 PM
  #18
Xride's Avatar
Thanks for all the tips, doesnt seem to difficult, and I think I have everything I need
One question though, about oil weight, is 10W30 ok to use, or only use that when its nicer out and use 5W10 for the winter when its cold?
Old Jan 26, 2003 | 09:59 PM
  #19
treyZ28's Avatar
-40* is cold
you oil is going to be very thich on startup.
thats why i say 5W10
Old Jan 26, 2003 | 10:44 PM
  #20
Xride's Avatar
Originally posted by treyZ28
-40* is cold
what temps is that good till? cause its warming up to about 15C average now, and with the crazy stuff we have had above freezing wouldnt be too odd.
Old Jan 26, 2003 | 10:46 PM
  #21
Laymaster's Avatar
I did this yesterday. I thought the drain plug was 14mm.
I use a PF35 oil filter, from AC Delco. The books say to use a PF25, but the PF35 is just a larger version of it. So for relatively the same price, the PF35 allows more filtering capabilities (more filtering media inside the filter). The choice is yours.
I also use 5 quarters. about 1/2 quart inside the filter, the other 4.5 inside the crankcase.
Old Jan 26, 2003 | 11:43 PM
  #22
14mm is the practical equivalent of a 9/16. (I know it is 14.28750mm, so don't go there )
Old Jan 27, 2003 | 02:12 AM
  #23
Laymaster's Avatar
I didn't see the post where 9/16 was mentioned.
for temps of -40 below...I would use Mobil 1 0w 30. It's rated to pour at -65 below.
Old Jan 27, 2003 | 05:19 AM
  #24
Patman's Avatar
In the cold winter months of Alberta, run 5w30, definitely synthetic too, the rest of the time you can run 10w30.
If you want to learn more about oil, here is a great message board that I'm a part of:
http://theoildrop.server101.com/ubb/ultimatebb.php
Old Jan 27, 2003 | 03:13 PM
  #25
Xride's Avatar
I was just reading teh SS owners manual supplement and it says that synthetic 5W30 should be used, and thats what SLP put in it. so should I jsut use 5W30 all year round, or 5W30 in the winter and 10W30 in the summer?
Old Jan 27, 2003 | 07:24 PM
  #26
Patman's Avatar
You could go either way, but I prefer to run 10w30 in the summer since it doesn't thin out as easily.
Old Jan 27, 2003 | 07:40 PM
  #27
ltlhomer's Avatar
Laymaster...
I said it was the 9/16" which is what I used and it worked perfectly. Not even the slightest amount of play so it has to be taht (or 14mm as the other guy mentioned). It definitly isn't 15mm unless like I said before my drain plug was somehow stripped a tad so that the 15mm had more than normal play. Either way, I'm sure he can figure it out ;-).
Old Jan 27, 2003 | 07:46 PM
  #28
TobyZ28's Avatar
1 quart is roughly 1 Litre for us Candiens eh.. It dont come in "quarts" up here lol
Old Jan 28, 2003 | 05:18 AM
  #29
Patman's Avatar
Actually some oils do. Pennzoil for one, you'll notice comes in 946ml bottles (one quart) as well as a few other specialty oils like Redline, Amsoil, Royal Purple, Schaeffer oil, etc.
Old Jan 28, 2003 | 03:07 PM
  #30
TobyZ28's Avatar
But theyre labelled 946ml bottles not 1 quart bottles! LOL (well correct me if i'm wrong hehe) Sorry just pickin
