first oil change question
Old Aug 8, 2008 | 08:02 PM
BLACK-HAWK's Avatar
it's time for the first oil change for the new motor after break in. how much do i need to put in with a rear mount? 5qt? i dont want to put in to much or to little
Old Aug 8, 2008 | 11:37 PM
95Blackhawk's Avatar
What do you mean by rear mount?
Old Aug 8, 2008 | 11:45 PM
BigBadBlack93Z's Avatar
put 5 qts in the pan (if its a 5qt pan), pull the stick and mark it at that level. start the car let the oil circulate shut it off then pull the stick, it should be a little lower, add to get back to that level. you should only have to add 1/4 qt or so unless you put in a cooler or extra filter, etc.
the reason i say mark the stick is because there are so many tolerances in production items that you can't just trust it, esp. if you've pulled the tube and not pressed it all the way or changed to a thicker pan gasket, etc.
Old Aug 9, 2008 | 01:25 AM
BLACK-HAWK's Avatar
will do , thank you! BBB93z
rear mount ='s rear mounted STS turbo
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
