first build
Old Jan 27, 2009 | 06:33 AM
cypress56's Avatar
first build
hey guys needing some help.starting my first engine build and would like to know from experience a good rotating assembly.im planning on running a cc465 xfi cam,trickflow heads,ported stock manifold,and a 125 shot on a 355.any input would be nice.
Old Jan 27, 2009 | 06:13 PM
Give us in idea of what kind of HP you are looking for, and what your budget is. How did you select the cam and the Trick Flows? Are the TF's going to be milled to get the 62cc chamber volume down and the compression ratio up where it belongs?
What is already done to your car? Might want to add a "signature", with year, model, engine, tranny and any current major mods. That way people will be able to help you better.
Old Jan 27, 2009 | 07:09 PM
bombebomb's Avatar
Like injuneer said, a little more info will greatly help us, help you. Getting an engine built when this is your first one takes a lot of research and questions. In the end though its a nice acomplishment.
Old Jan 27, 2009 | 09:05 PM
cypress56's Avatar
as the cam goes it just kinda jumped at me and i would like to match everything for it,the heads will be milled.dont really have a specific hp goal i gues around 500 hp.trannys good for 1000 hp easy.i have 5 grand to start the motor.not 100 percent on the nitrous might try to stay n/a.
Old Jan 28, 2009 | 07:12 PM
cypress56's Avatar
would it be a bad idea to just get the cam kit and have the stock heads worked.
Old Jan 28, 2009 | 07:22 PM
bombebomb's Avatar
Most people will tell you that the heads pick the cam, not the other way around.
Do you mean 500whp
or 500 hp at the engine. Because stock heads will not make 500whp without forced induction, or nitrous (as far as I know).
Old Jan 28, 2009 | 07:28 PM
cypress56's Avatar
to the wheels would be good but im not picky as long as my cars stays together.guess ill just through it together and see how things work out.trail and error
Old Jan 28, 2009 | 08:20 PM
bombebomb's Avatar
Trial and error with car engines
If thats what you want to do though, you can. Lots of proven combos out there for the LT1 to just be "guessing" at what to buy.
Old Jan 28, 2009 | 09:18 PM
96capricemgr's Avatar
Slow down and start playing with boltons.
"building" an engine at this stage would be a big expensive mistake.
Properly worked the stock heads ARE capable of over 500rwhp, you aren't going to get there though, many "professionals" can't, yet some true professionals exceed that number solidly.
Novo
Jun 14, 2016 02:58 AM
CARiD
Sep 30, 2015 05:44 AM
pepon214tx
Sep 20, 2015 04:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
reww86
Aug 29, 2015 06:04 PM
