First 93 lt1 need help
Old Nov 2, 2005 | 02:41 PM
BIGCOWL-IMP's Avatar
ok i picked up a 93 formula and was able to drive it for the first time today and went around the block and when you go to give it gas it almost wants to die and i hurd a pop once.
I`m geussing opti spark is bad from sitting for about 2 years and has 94,xxx miles.
I`m thinking of switching it over to a vented opti but what all do i need ??
I already have a extra 95 opti and 95 timeing chain cover.
Do i need a 95 chain cover?? if so why ??
But the pin in the cam is it short correct???
Mybe its not worth it and just put a new 93 opti back on ???
Old Nov 2, 2005 | 03:24 PM
faded93bird's Avatar
Re: First 93 lt1 need help
You need to pull out the dowl pin, get a 95+ cam gear for the timeing set, the harness for the conector is also a different part and style, and get the vaccume harness.
So yeah thats it
Old Nov 2, 2005 | 04:25 PM
cammed_aro Z28's Avatar
if i remember right, the 95 timing cover has a bigger hole infront of the cam, remember, instead of having like a 1/2" diameter splined shaft spinning in the middle, you have a 1/4' dowel spinning on the outside. DEFINITELY dont forget to get a new plug for the opti, i swithed mine over and couldnt figure out why it wouldnt start. the plug fits in the hole but it is not long enough to make contact. you can get just the plug end from a chevy dealer for about $3 if you feel like using a pin tool and removing the pins from the old plug and putting them in the new one.
Old Nov 2, 2005 | 05:36 PM
http://www.automotiverebuilder.com/a...nts/99928e.gif
Old Nov 2, 2005 | 05:59 PM
redington's Avatar
i looked at switching mine too but you have to have like $200 in misc parts and then switch the cam.... **** that you can get a diff system for like 700 and not have to mess with the cam.
Old Nov 2, 2005 | 08:11 PM
That you Injuneer
Screw it im just putting a 93 back on it
Who`s got the cheapest price
Old Nov 2, 2005 | 08:17 PM
IrocManiac's Avatar
Could be the opti you probably should check out the catalytic converter too. On a 3rd gen a friend of mine had it was doing a similar thing. The cat was clogged all to hell. Replaced it the car ran like a champ.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
