Fired up the motor today!
Old Mar 11, 2007 | 10:05 PM
Brandon94Z28's Avatar
I put a 94z28 LT1 into my 95 Impala SS. It started right up and I let it run for a few seconds so I could make sure there were no leaks. Started it back up and it was running really rough and stalled. I checked all the plug wires and they were right. I put the hotcam kit in it while the motor was out. We put the hotcam in right after we replaced the stocker with out moving anything. Did 1/2 turn past lash. Could it be running this bad due to NOT having the egr and air hooked up and not having it tuned out? I am going to get a tune from pcm4less this week(right now the car has a 6speed tune and my car is an auto)
What else should I be looking at?
Brandon
Old Mar 11, 2007 | 10:14 PM
LiENUS's Avatar
You using the impala pcm or the 94z pcm?
Old Mar 11, 2007 | 10:32 PM
I am using a 6speed pcm from a 95 z28.
Old Mar 11, 2007 | 10:35 PM
LiENUS's Avatar
Get an auto tune.
Old Mar 11, 2007 | 10:59 PM
95Blackhawk's Avatar
Those things won't be an issue regarding running rough.
More details you can give on the issue? How old is the gas?
Very much doubt it is a tuning problem.
Old Mar 12, 2007 | 07:26 AM
I bought the car with no motor and the guy said it had been sitting since June. The first time I fired it up only the passenger fan started, the second time both came on right away. The motor has been sitting since 1999. It was all wrapped and oiled though. I had some of the msd stuff hooked wrong and it would crank and crank.. Wonder if I kinda flooded it.
thanks
Brandon
Old Mar 12, 2007 | 09:09 AM
2000GTP's Avatar
Double check your work and make sure there are no vacuum leaks in the system. Also, if the motor has been sitting for a long time, maybe the MAF is dirty and that could lead to a rough running car. It wouldn't hurt to clean that either.
Noenav
Mar 1, 2019 07:38 AM
ChrisFrez
Mar 1, 2015 01:33 PM
Jazsun
Dec 29, 2014 12:14 PM
ChrisFrez
Dec 7, 2014 11:32 AM
StngStlkr
Sep 6, 2002 05:47 PM
