firebird putters around right hand turn
Old Oct 20, 2006 | 05:52 PM
sports418's Avatar
When ever I make a right hand turn whether it be on the highway or in the city, my 94 firebird starts to putter. Sometimes almost to the point to where it is going to stall out. And after the first right hand turn, it will also putter on a straight away. Any suggestions on what can be wrong?
Old Oct 20, 2006 | 06:21 PM
americanmusscle's Avatar
Re: firebird putters around right hand turn
Power steering pump going bad maybe or belt slipage.
Old Oct 20, 2006 | 06:26 PM
sports418's Avatar
would a power steering pump bog the engine down like that? I was thinking something might be wrong with the fuel pump? is that a possibility?
Old Oct 20, 2006 | 06:51 PM
Guest47904's Avatar
Guest
Does fuel level have anything to do with it?
Old Oct 20, 2006 | 07:27 PM
sports418's Avatar
well i just filled up this morning and its doin the same thing....i thought maybe it could have just been some bad gas but i ran it low and filled up at a different place and its still doing it...
Old Oct 20, 2006 | 09:49 PM
Ricardo's Avatar
I had the very same problem in another car. Not an F body but the problem was very similar. Only difference was that in my case the problem would come up when turning left. I installed a fuel pressure gauge and drove it. the fuel pressure would fall close to 15 psi and then rise again. I then checked the electric supply to the pump during the low pressure event thinking that it might be a wiring issue and it was not. I then had my son driving while I listened to the pump with a stetoscope during the pressure drop and the pump kept running all the time.
It turned out being the fuel pump suction strainer being clogged. It would hold a bubble of air and when you turned left the pump would cavitate for a short while and then pick up pressure again. the problem would be more evident when the fuel level was low.
RG
Old Oct 20, 2006 | 10:59 PM
sports418's Avatar
So where would the suction strainer be located at? Is it in the tank with the pump?
Old Oct 21, 2006 | 05:41 AM
Guest47904's Avatar
Guest
Yes the "sock" is in the tank.
So first you get a fuel pressure gage with a hose and tape it to the windshield and drive around to see what is happening with fuel pressure.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
meissen
Jun 1, 2015 07:59 AM
CaRParts102
Dec 6, 2014 08:45 AM
formula79
26
Aug 5, 2002 12:21 PM
