lots of spark retard, 94 ta m6.
Old Oct 20, 2006 | 10:19 PM
busta9876's Avatar
Okay, datalogging a 94 M6 TA, only mods are cold air kit and 4.10 gears.
During a drive it does okay cold, but once warmed up it will buck hard around 1700 rpm wot. spark retard is constant at this point. I even went in and took out 5 degrees of timing and it is still pulling timing.
I reved it a few times in neutral and twice I got it to pop back into the intake.
sound like opti?
attached is a datalog after I pulled 5 degrees from 80-100 kpa 2800 to 6000 rpm ranges
http://www.lt1swap.com/datalog2.uni
Old Oct 21, 2006 | 05:46 AM
Guest47904's Avatar
Guest
Re: lots of spark retard, 94 ta m6.
Disconnect an O2 and see if it runs better even after the SES sets.
markzzzz
May 8, 2015 09:21 AM
charchri4
Apr 14, 2015 06:40 PM
nophix
Nov 30, 2014 10:26 PM
Dolby109
Aug 5, 2002 04:44 PM
