Finished grinding down dowel pin and installing opti
Old May 3, 2003 | 12:10 PM
94foormula's Avatar
Well I finally got the dowel pin/opti issue finished last night. I ended up taking a good amount off. From the measurements I took the dowel pin protrudes 6mm or so into the 10 mm indicator slot of the opti. I took a little extra off just so I dont have to go through this again.
Now just to make sure i put the opti on right I rotated the bearing until the slot was lined up with the dowel pin then just slid it on. I pushed around the opti and made sure it sat flush before I bolted it up, which it did. Does this sound alright?
Old May 3, 2003 | 12:14 PM
The dowel on my original opti went about 2/3 of the way in, just as what you are saying yours now is. You sound ok to me.
Old May 3, 2003 | 12:32 PM
Don 97 SS's Avatar
That sounds like a winner to me. Button everything back together and fire it up.
Richardan15
May 30, 2015 08:36 AM
Collector Car
Jan 5, 2015 10:58 AM
thenewkid
Nov 27, 2014 09:41 AM
GigaMp3z
Feb 20, 2003 02:57 PM
