Finding TDC ?
Finding TDC ?
I need to adjust my roller rockers on my new engine. I have an ATI Super Damper on it which is degreed with a TDC mark. My question is... do I put the TDC mark straight up at 12 o'clock for #1 TDC.
thanks
thanks
Not sure how your damper is marked so the only sure fire way to find TDC on #1 is watch the rockers when the piston is on it's way up the cylinder and the valves are both closed. Use a stick in the cylinder through the plug hole to see the movement of the piston. When it's at the top of the stroke and both valves are closed, that's TDC.
Follow this instruction from Rob, thanks Rob.
http://shbox.com/1/4th_gen_tech2.html#adjust_valves.
Scroll down about 1/3 from the top.
Sarahrope64
Nov 27, 2014 11:17 AM
smokin5s
Jul 24, 2003 10:47 PM
