Finally some numbers for my setup...
Old Jul 25, 2007 | 05:42 PM
  #46
MTL_Z28's Avatar
sorry about the huge pics guys...
If the mods want I can resize them.
Old Jul 25, 2007 | 06:00 PM
  #47
marshall93z's Avatar
Did you read post #45?
Old Jul 25, 2007 | 06:05 PM
  #48
MTL_Z28's Avatar
Originally Posted by marshall93z
Picture #3.....the rocker is WAAAY out of wack!
Do you think it could be the guideplate? What would cause a NSA rocker to be off like that?
Actually a few rockers I felt had some 'play' in them on the valvesprings, I just assumed it was all normal.
Old Jul 25, 2007 | 09:28 PM
  #49
Quickz1670's Avatar
Those rockers are way off center.
http://web.camaross.com/forums/showthread.php?t=460413
Old Jul 25, 2007 | 09:31 PM
  #50
Z-RATED94's Avatar
Originally Posted by Quickz1670
So what guidplates are those? That is really sad.
Old Jul 25, 2007 | 09:51 PM
  #51
MTL_Z28's Avatar
I have the combination motorsports guideplates.
Old Jul 26, 2007 | 08:48 AM
  #52
Sweetred95ta's Avatar
Originally Posted by MTL_Z28
I downloaded the log and was going to sift through it, but not after seeing your rockers. That could be causing all kinds of issues, including lack of performance and knock retard. I didn't really see any rockers with 'normal' wear patterns on the tip; they're all off center. I'm surprised you haven't broken anything yet. You may want to check your valve guides when you pull this stuff apart.
Old Jul 26, 2007 | 01:06 PM
  #53
MTL_Z28's Avatar
Could that explain my slight oil consumption issue but no smoke?
Old Jul 26, 2007 | 01:14 PM
  #54
Mortify's Avatar
Lets just say... get it fixed asap.
Old Jul 26, 2007 | 04:45 PM
  #55
SS RRR's Avatar
I'd like to see other angles of this rocker. Is it on the pushrod? Is that the only rocker that is that far out of whack?
Old Jul 26, 2007 | 05:08 PM
  #56
MTL_Z28's Avatar
Well from the pictures there are others that are similar.. like on the #2 cyl. you can see both rockers on the intake & exhaust are off center as well. Also just by looking at the wear patterns on the rocker tips (#4) you can see there are a few that are irregular and not centered on te valve tip like sweetred95TA has already pointed out.
Old Jul 26, 2007 | 10:33 PM
  #57
street demon2k3's Avatar
anyone know what might cause the rockers to be off center? Bent pushrod maybe IDK?
Old Jul 26, 2007 | 11:00 PM
  #58
ulakovic22's Avatar
Incorrect spring height, bent pushrod for lash being set too tight, guide plate being way off, could be a lot of things, just got to tear into it and see.
DirtyDaveW
Dec 1, 2016 05:37 PM
RickRay
Events and Cruise Spots
Apr 23, 2015 02:50 PM
C6LS3
Apr 15, 2015 09:50 AM
madman69
Aug 18, 2002 03:58 PM
Dragonballz28
Jul 25, 2002 03:19 PM
