Finally some numbers for my setup...
I downloaded the log and was going to sift through it, but not after seeing your rockers. That could be causing all kinds of issues, including lack of performance and knock retard. I didn't really see any rockers with 'normal' wear patterns on the tip; they're all off center. I'm surprised you haven't broken anything yet. You may want to check your valve guides when you pull this stuff apart.
Well from the pictures there are others that are similar.. like on the #2 cyl. you can see both rockers on the intake & exhaust are off center as well. Also just by looking at the wear patterns on the rocker tips (#4) you can see there are a few that are irregular and not centered on te valve tip like sweetred95TA has already pointed out.
