Finally Found the Valve Cover Modification Link
Old Jan 8, 2005 | 01:19 PM
stereomandan's Avatar
I remember seeing this a while back, but for all my searching on this site, I couldn't find out how the stock valve covers needed to be modified for Pro Magnum RR's.
Here's the link I found on the net:
http://www.hotss.com/Members/scott_vaca/pro-mag.htm
Hopfully this thread will pop up when others do a search now.
Dan
Old Jan 8, 2005 | 02:24 PM
Silvershark's Avatar
Re: Finally Found the Valve Cover Modification Link
Good Find!
I have been looking for this for quite some time now.
Old Jan 8, 2005 | 02:38 PM
Z28Nut's Avatar
I used that guide when I put in my Comp RRs. Worked like a charm.
Old Jan 8, 2005 | 02:42 PM
Originally Posted by Silvershark
Good Find!
Glad to help.
Dan
Old Jan 8, 2005 | 03:25 PM
Bersaglieri's Avatar
Dan
Allow me... Comp Cam CC Roller Rockers Pro Mag Magnum 1.6 RR Ratio Valve Cover mod modification stock valve covers fit pro mags support braket bend Pro mag install installation
-Dustin-
Old Jan 8, 2005 | 05:13 PM
Dan
Old Jan 8, 2005 | 05:47 PM
flusz28's Avatar
do i need to do this mode for my crane gold 1.6rr ?
Old Jan 8, 2005 | 05:55 PM
I dont think so, but it wouldnt hurt either. Not necessary for the crane style including the LT4 RR.
-Dustin-
Old Jan 8, 2005 | 05:57 PM
flusz28's Avatar
i can set the valve cover down on tp of them with out any problem. how would i know if they were not clearing the cover? would it screw something up as soon as i started up the car?
Old Jan 8, 2005 | 10:46 PM
You would feel the clearance problems, most likely, when you put your valve covers on. You would feel the rockers hitting the valve cover.
I've never heard of doing this mod with Crane RR's. It's just a Comp Cams Pro Magnum mod.
Dan
Old Jan 9, 2005 | 08:01 AM
flusz28's Avatar
alright cool thanks Dan didn't want to have to mess around if i didn't have too.
Old Jul 25, 2005 | 09:11 AM
Jazsun's Avatar
Wow, thanks a lot good Idea making this thread, I did a search and this came up pronto! Promps!
Old Jul 25, 2005 | 09:32 AM
Another Red Z's Avatar
There is no need for the mod if you are using the Crane rockers.I have used both the GMPP SA rockers(made by Crane) and the Crane gold race with out any problems.
Old Jul 25, 2005 | 12:11 PM
NBred94's Avatar
Used that technique myself, works like a champ.
Now if someone could invent a temporary finger shrinking procedure, installing RR's and valvesprings would be simple.
Old Jan 18, 2006 | 07:40 PM
TransAm396's Avatar
this post just saved my ***..
