final plea for help...[EDIT] LT1
Old Dec 15, 2005 | 11:38 PM
white93lt1's Avatar
ok so i posted a thread a while ago about my car misfiring and bogging and so i changed the cap and rotor, then it wouldnt start so i took the starteroff and it was crcked in half....so i get a new one then it started better but wouldnt fully start it wants to but just cant ........i have checked my coil is good, i am gettign spark...my fuel pressure is good, fuell tank ios good....starter boleted up fine....i dont know why now its not starting....u think its b/c i only did cap and rotor...anf all along the problem was in the distrubator?....i am about to just take it to a shop b/c i dont know what else to do anyone please help me
Old Dec 15, 2005 | 11:58 PM
1racerdude's Avatar
Re: final plea for help...****ing LT1
A shop would be better than throwing expensive parts at it. A dealer has the stuff th check it with. It probably needs a scan and they can see.
Not just any shop but one who has the machines to scan and check it.
Old Dec 16, 2005 | 12:14 AM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
i avoid shops until i am totally stuck. new opti's are down to 160 ish with the new jegs and mallory aftermarket (ha take that gm). i would keep troubleshooting. i cant see a shop doing any diagnostics for you for less than a 100. that doesnt even mean they will find the problem.
david
Old Dec 16, 2005 | 01:23 AM
Deenasty's Avatar
you do know the opti is composed of the cap and rotor, and the optical side? How do you know your getting spark and that the fuel is actually getting out of the injectors? You might have fuel pressure at the rail, but the fuel could not be spraying out of the injectors if the optical side of the opti is bad, cause it uses that as a source for when the injectors should fire..
Old Dec 16, 2005 | 06:39 AM
teke184's Avatar
not to mention you have a cam...so no dealer will touch it.
i tried taking my 99 to a dealer for a misfire...they looked at the LT headers and removed emissions and called it a "higly modified race engine" and wouldn't even scan it. and this was BEFORE my cam.
dealers are just parts swappers. change things till it fixes it. regardless if the part is bad or not.
Old Dec 16, 2005 | 01:38 PM
white93lt1's Avatar
well first off i am no mechanic am i have been doing all the **** myself and it was my first time...my buddy came over with this thing i dont know what it is...and he told me i was getting spark..but my buddy owns a shop with someothre guys so i willl have to pay for it but it is not going ot be some random legit shop...i know that there are different parts of the opti..and right now iam thinking that it is the other part not the cap and rotor b/c i changed it...so i am prettymuch gogin to take it in scan it and then eee what he says if he says that opti im gonna do it myself ...but this car is my daily driver and i am at a point where i dont know hat to do and i dont have the tools to do ****...like a scanner or anythihgn
Old Dec 16, 2005 | 03:45 PM
1racerdude's Avatar
I have an opti for sale if ya need one. Brand new Delco.
Old Dec 16, 2005 | 04:25 PM
Deenasty's Avatar
its easy to tell if its the optical side that is bad. Hook up a scanner to it, and while your cranking, if the rpm's dont move on the scanner, the optical side is bad..
Old Dec 16, 2005 | 04:51 PM
silverlt1ss's Avatar
p/m sent
is your engine light on and blinking when you get on the gas???? my buddy's did the same thing on his 97... he replaced whole opti.. wires...plugs...coil...and module and still performed like **** and ran the same... it turned out that it was an oxygen sensor...one of the front 2 sensers(in front of the cat) if you have a 96 or newer. but i would try a 40 dollar sensor before pulling an opticrap off again.
Old Dec 16, 2005 | 08:07 PM
PredatorZ28's Avatar
check the fueses my fuese went out one time and my car would try and start but wouldnt..
Old Dec 16, 2005 | 08:18 PM
Cmr0z28's Avatar
You checked for spark at the plug wires or the coil?
Usually changing the cap and rotor doesn't fix the problem....the whole opti should be replaced.
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
ChrisFrez
Dec 7, 2014 06:01 PM
Bando
Aug 2, 2002 02:18 PM
Aneurysm
Jul 22, 2002 08:42 PM
