Figured out why my motor blew up...
Old Jun 15, 2008 | 05:41 PM
95camaro3800's Avatar
Pulled the other head off the block today, and immediately after it popped off, my eyes grew big. Check this out:
Old Jun 15, 2008 | 05:44 PM
MeanGreen97Z's Avatar
WTF is that metal piece? Carnage... that sucks man!
Old Jun 15, 2008 | 05:48 PM
firetird's Avatar
i think that's a result of your motor blowing....
what were the details on the situation? Did you hear a knock then it blew up or what?
Old Jun 15, 2008 | 06:08 PM
ShownomercyZ28's Avatar
Geez, wtf is that?
Old Jun 15, 2008 | 06:49 PM
MachinistOne's Avatar
What the heck is that piece in the first picture????
Old Jun 15, 2008 | 07:07 PM
It's a valvespring retainer. I'm thinking whoever had the car before me and my buddy bought it (he owned it before me), had it lying in the intake manifold, and after all this time it found its way through the intake port, and with the higher lift cam, finally squeezed its way under the valve, and caused that. I'm going to pull the oil pan off soon and see if the crank broke at all.. the harmonic balancer is messed up pretty bad. It's egg shaped, and all the rubber was somehow pushed to only half of it.
Old Jun 15, 2008 | 07:12 PM
Don 97 SS's Avatar
Eep ,that looks bad. Got any pics of the piston? Is it toast too?
Old Jun 15, 2008 | 08:10 PM
I did, but I must have deleted them. I'll take more later.
And yes, the piston is pretty demolished as well, almost as bad as the head.
Wow, never have seen a retainer get into the cylinder before - nuts and bolts are pretty common...
Old Jun 16, 2008 | 08:22 AM
cause4panic's Avatar
THERES your problem!!!
Plug gap looks a little tight.
damn that sucks
Old Jun 16, 2008 | 12:13 PM
bombebomb's Avatar
Wow... carnage
Old Jun 16, 2008 | 03:31 PM
Jazsun's Avatar
What is that dent by the intake valve caused by? Looks kinda like a flathead screw.
Old Jun 16, 2008 | 06:42 PM
How are the cylinder walls? Is the block reusable? You'll need a set of pistons for sure. Now you can get some ported heads and build a 355.
Old Jun 16, 2008 | 09:59 PM
Pontiac_97's Avatar
ahh, some 800 grit sand paper will take those tiny scratches right out
Old Jun 16, 2008 | 11:51 PM
Check the sig, I'm two steps ahead of ya
The cylinder walls look just fine, but I'd recomment getting them bored/honed. The shortblock is from a 94 Vette LT1. I think the block is still good, but I'm no expert. If someone wants to buy it, PM me
