a few ?s before JET HOT LT install
Old Jul 1, 2005 | 02:26 AM
  #16
Heatmaker's Avatar
Advanced Member
Re: a few ?s before JET HOT LT install
For my Y-pipe I brought an off the shelf Hooker from summit. It clears perfectly... about an inch off room. It was annoying to line up, so I had the muffler shop adjust it a little so it's easy to line up. I had them weld my Cut outs on each side of the Y- pipe and I cut the rear I pipe off and had the cat put in place there. It was a simple solution, but all I can say is that the kit works very well. I don't know who posted the rumor about the cat not working in the I pipe location, but it's false. The Cat gets extremely hot, I mean hot. It turned the SS gold plenty quick, and I for some reason decided to touch it....only to find out why I don't listen to rumors anymore. But that setup works very well. Good luck.
Old Jul 1, 2005 | 02:59 PM
  #17
CamaroSS30thAnn's Avatar
Originally Posted by JJJ93z
CamaroSS30thAnn what brand locking bolts did u get? the speed shop by my house has Stage 8s but it looks confusing, i seen some that you put a allen wrench in the middle and turn it once the actual head on the bolt is fully in , i just forget what brand those are.
Madwolf, pmed ya
breslin locking header bolts (ones with allen head in middle) the stainless steel one are expensive but worth every penny , now i just have to install them
Old Jul 1, 2005 | 04:25 PM
  #18
JJJ93z's Avatar
where did u get them from, im havin trouble finding them at summit. do u have a part #? and they are the 1" right?
Old Jul 1, 2005 | 05:44 PM
  #19
summit part number BPP-600-102
3/8 - 16 x 1 inch
Old Jul 7, 2005 | 05:20 PM
  #20
JJJ93z's Avatar
i just got my percys gaskets and breslin locking bolts in starting later today hopefully
Ion , did u get my pm?
Old Jul 7, 2005 | 05:46 PM
  #21
LtsRace's Avatar
I just ordered the stage 8 lockers from summit 10 minutes ago.
Old Jul 7, 2005 | 07:55 PM
  #22
JJJ93z's Avatar
get a good price on em? mine were extremely pricey, but stainless and they look pretty straight forward. they got here in like 2 days.
Old Jul 8, 2005 | 12:09 AM
  #23
JJJ93z's Avatar
just got done pulling the y pipe off which was not a cake walk, gonna drop the starter and pull the manifolds in the morning. Any tips on which swivel/extension combo people have used would be great! thanks
Old Jul 8, 2005 | 12:47 AM
  #24
Heatmaker's Avatar
Advanced Member
Shoot them with PBNutblaster and let them sit... I recco getting them with a breaker bar first.
Old Jul 8, 2005 | 05:24 PM
  #25
LtsRace's Avatar
I paid 42.99 for the set of Stage 8 lockers. But I dont think they are stainless.
Old Jul 26, 2005 | 08:56 PM
  #26
JJJ93z's Avatar
2 things first i took off that plastic boot on the steering column , does it need to be there when it runs? and when i jack the motor from the bottom should i have the car on stands then place some 2x4s under the oil pan and jack from there? thanks
Old Jul 26, 2005 | 09:00 PM
  #27
thats the best way to do it
i just did my install this weekend,
for one i HIGHLY reccomend changing the motor mounts, i did not and im running into fitment issues everywhere, i shall change them this weekend
2nd i didnt even put teh plastic back onto the steering shaft or it would not rotate and u may have to been teh metal tabs on the linkage
third , does ur y-pipe have the indentation on it to clear teh crossmember , if not id reccomend calling jet hot lol , mine did not i have a buddy taking care of it
Old Jul 26, 2005 | 09:03 PM
  #28
JJJ93z's Avatar
what kind of mounts are you going 2 put in?
alright so i think it has a bend , its flattened on the driverside heres some pics
http://community.webshots.com/photo/405587431MWFwLB
http://community.webshots.com/photo/405563268iJjCXl
also when you put your Y pipe together did it line right up with your I-pipe ? like in the dead center of the car? it looks like mine may be a little longer after its put together. thanks for the help
Also when jacking the motor where should i put my blocks? under the oil pan? and can i leave the dr. side header on when i jack it? thanks
Old Jul 27, 2005 | 07:48 PM
  #29
JJJ93z's Avatar
i ordered the energy suspension mounts today should be here saturday
CamaroSS30thAnn do i have the right piece (in post above)
Old Jul 27, 2005 | 10:03 PM
  #30
thanks for the pics man , yeah u have teh right one
jet hot sent me two passenger side pipes so my buddy had to call them since i orederd through him , now i justneed to wait and c what he says
i believe i got enegry suspension poly mounts,
He had installed jethots b4 and teh y-pipe may be a bit long
im doing the install by myslef with a friend to save money lol , i though i could save a few bucks by not getting teh mounts , looks like i was wrong
if u need to know anything about the jethots or the install let me knwo
is that ur Z in the backround?
looks good let me know how the install goes , it really was not as bad as i thought it would be , will i do it again ......................maybe
