a few ?s before JET HOT LT install
Old Jun 28, 2005 | 11:10 AM
JJJ93z's Avatar
first off , i want to use copper gaskets, which brand and are they all the same for headers? (not a jet hot specific one ect..) also locking header bolts , which brand and finally any JET HOT walkthrough links would be helpful.. thanks
Old Jun 28, 2005 | 12:01 PM
Paul87's Avatar
Re: a few ?s before JET HOT LT install
Here's a guide http://zmydust.com/headers/install.htm
Old Jun 28, 2005 | 01:22 PM
JJJ93z's Avatar
awesome guide.. thanks
should i get 02 extenders? also factory or aftermarket o2 sens. or o2 simulator?
Old Jun 28, 2005 | 01:45 PM
madwolf's Avatar
You will need one extension for the passenger side.
I have two 93 AC Delco (GM) o2 sensors with 2000 miles on them and the extension you need if you're interested. $60 shipped for everything.
Old Jun 28, 2005 | 04:13 PM
Heatmaker's Avatar
Advanced Member
jack the motor
Old Jun 28, 2005 | 09:46 PM
magnumv8's Avatar
As far as gaskets, I would recomend using Felpro gaskets. Regardless of brand, just make sure they have the "d" shaped port openings.
Old Jun 28, 2005 | 10:01 PM
CamaroSS30thAnn's Avatar
good luck , i cant wait to do mine, hopefully soon , just ordered lockign header bolts and extensions
am i set , i have
headers , ory
copper gaskets (for now ) also some high temp rtv sealant
collector gaskets (ones that came with teh headers)
extensions
header bolts
pb blaster
anything else i need?
Old Jun 28, 2005 | 10:03 PM
JJJ93z's Avatar
am i set , i have
headers , ory
extensions
header bolts
pb blaster
what did u need the rtv sealant for?
also what kind of clamps are you using for the pipe coming from the collector to the y pipe
Old Jun 28, 2005 | 10:10 PM
to help create a better seal aroung the gasket area, even tho it may burn off anyways
do u mean the y-pipe to the i-pipe???
Old Jun 29, 2005 | 08:06 AM
Mystic97Z's Avatar
am i set , i have
headers , ory
extensions
header bolts
pb blaster
a custom y pipe,,maybe.. alot of people have to take their cars to a muffler shop to have a custom y pipe made cuz the drivers side header points up underneath the car, and the y pipe wont clear the tranny crossmember, even with the dent. good luck, some shops wont do that cuz it wont have cats....i would recommend using gm gaskets..also, don't rtv the gaskets on the header/head surfaces. that will just create spots to leak. good luck, watch out for the low coolant sensor also.
Old Jun 29, 2005 | 10:49 AM
MPZ28's Avatar
I just put Jet Hot LT's and Y-pipe in my car . Perfect freakin fit all the way . Not extra bends or anything. ( I drive a 96 z28)
Old Jun 30, 2005 | 03:31 PM
JJJ93z's Avatar
mystic ........ i also got a jet hot Y pipe too, because my z has a elec cutout in place of the cat and the guy at midas freaked out once he saw it and took it back down from the lift. why should i be worried about low coolant as well ?
Old Jun 30, 2005 | 07:01 PM
JJJ93z's Avatar
thats exactly what i ment thanks
Old Jun 30, 2005 | 07:56 PM
JJJ93z's Avatar
CamaroSS30thAnn what brand locking bolts did u get? the speed shop by my house has Stage 8s but it looks confusing, i seen some that you put a allen wrench in the middle and turn it once the actual head on the bolt is fully in , i just forget what brand those are.
Madwolf, pmed ya
Old Jun 30, 2005 | 09:11 PM
JJJ93z's Avatar
Also should i put my wires on after the LTs are bolted down? (ive never done plugs/wires) on a lt1 before.( and yes ive done a search for the last half hour or so)
thanks
