Few questions here, please help!
Old Apr 8, 2003 | 06:38 PM
CDN WS6's Avatar
Question Few questions here, please help!
I was wanting to find out a few things.
1)I'm installing mac headers with an off-road pipe on a 97. What o2sims do I need, flat or square connectors(I'm thinking square)?
2)what is the part number for the fuel filter and how hard is it to change it?
3)back to the headers, should I use aftermarket bolts? My brother used the supplied bolts and has had no problems.
Thanks for the help!
Old Apr 8, 2003 | 06:58 PM
EviLBoX's Avatar
You will need the square connector O2 sims. I think that's the only O2 sim available for GM cars/trucks anyway.
I recommend using stage 8 locking bolts, not only do the locks keep them from backing out, but you can use an allan wrench socket on them (if you have room).
Old Apr 8, 2003 | 07:04 PM
94F1Z28's Avatar
Well i don't know the part number for the fuel filter,just get one at the dealer and it is not that hard to change.Also i have MAC headers and i used the bolts and gaskets that came with them and had no problems but i did tighten the bolts about every month or so and when i did my heads i used the stock GM exhaust gasket and have never had to tighten the headers bolts again so i highly recommend the GM exhaust gaskets.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
