Few Questions....
Old Apr 6, 2005 | 09:44 PM
Hawk350's Avatar
Few Questions....
Replaced my valve cover gasket today, that was not the oil leak that I anticipated. Took the car for a ride, still leaks. Took a mirror and ran in on the back on teh engine, and the seal on the manifold in the very back seems to be the oil leak. My question is: The leak seems to be coming from one location that is approx and inch wide. My thinking is, correct me if I am wrong but I wanted to clean the surface and seal that up with some gasket maker. I am looking for a quick fix, will this hold? The leak is approx _____ long. My second question, can a check engine light be triggered from an exhaust leak? Thanks for any input.
Old Apr 6, 2005 | 10:34 PM
Robs97Z28's Avatar
Re: Few Questions....
the only way to fix the intake leak, is to pull the manifold. then clean the manifold, heads and block of any dirt and oil. Replace the 2 manifold gaskets and use rvt to seal beweet the block and manifold.
SKmaroZ28
May 17, 2014 07:17 PM
PaNaRaMuH
Jan 27, 2013 10:53 PM
Collector Car
Nov 5, 2012 02:59 PM
