a few 377 ?'s
Old Dec 28, 2003 | 01:09 AM
96LT14u2Nv's Avatar
a few 377 ?'s
alright, i know these are prolly a little stupid but i am a little confused.
i am going to build a 377 b/c i have a block that doesnt need to be bored, just needs honed. so.....i have a 383 crank (3.750 stroke) and i am going to use stock 5.7 LT1 rod)s. now the ? is.......do i buy pistons for a 350 (3.480) or for a 383 (3.750)? what balacer do i need?
also, the crank is internally balaced. what else do i need to do? i plan on getting all the rods/pistons/crank balanced and blueprinted together, is that all that needs to be done?
also, will a stock LT1 oil pan work or do i need a 400 small block pan/or special pan to clear the extra stroke crank?
thanks and go ahead and let me know some other things i may run into
Old Dec 28, 2003 | 03:01 AM
97WS6SCharged's Avatar
Exactly what block and crank are you using?
If you use a 350 block and a 3.75 inch crank, you're going to displace 383 CID whether you use a 5.7" or 6" rod. To build a 377, you have to put a 350 crank (3.48" stroke) into a 400 block.
Old Dec 28, 2003 | 10:09 AM
Josh-'04 GTO's Avatar
Incorrect. A 377 LT1 is a 3.75" crank with 4.000" bore size. I happen to own one! Since I'm the only owner of my WS6 since new, I couldn't stand the thought of overboring a like-new block. Plus I want all the block integrity I can get with over 650 fwhp.
96LT14u2Nv-You need to buy pistons for a 3.75" stroke with 5.7 rods (383 pistons). They are off-the-shelf common. The only difference is you need to buy standard bore ones, not .030" oversized (remember 4.000" bore).
I found with my stock oil pan that it had to be "clearanced". This usually means a little "massaging" with a ball pean hammer. I plan on getting a different oil pan this spring, but the stocker has worked fine for 2 years.
Old Dec 28, 2003 | 01:42 PM
96LT14u2Nv's Avatar
thanks Josh, that is what i figured but just wanted to double check. BTW, what balancer are u using? thanks, dj
Old Dec 28, 2003 | 02:20 PM
No prob.
I'm using the standard LT1 balancer. I don't turn more than 6400 rpms so things have been fine so far. But as I get crazier with the motor, I'll probably try one of the aftermarket ones.
Old Dec 29, 2003 | 09:32 AM
You're right, sorry about that, I guess I assumed he would bore the block to make sure the cylinders were straight. My bad. Didn't have my cup of coffee when I read the original post.
Brad.S Camaro
Jan 17, 2010 06:03 PM
Slick_Sammy
Advanced Tech
Nov 28, 2006 11:55 PM
jkucz31
May 2, 2006 09:12 PM
IgorT.455/406
Classic Engine Tech
Jun 13, 2002 08:31 PM
